Author Topic: wishlist  (Read 2103 times)
wishlist
« on: September 10, 2018, 05:37:46 AM »
Would it be possible to export standard compositions from standard database, into calczaf for calculating ZAF and K-values using specified composition.
Re: wishlist
« Reply #1 on: September 10, 2018, 12:13:31 PM »
Almost everything is possible!   :)
Since the Standard app already outputs the matrix corrections and k-ratios as seen here:
St   19 HfSiO4 (Hafnon)
TakeOff = 40.0  KiloVolt = 15.0  Density =  6.900  Type = silicate
Synthetic material
Flux grown by John Hanchar
Elemental Composition
Average Total Oxygen:         .000     Average Total Weight%:  100.000
Average Calculated Oxygen:    .000     Average Atomic Number:   50.841
Average Excess Oxygen:        .000     Average Atomic Weight:   45.096
ELEM:       Hf      Si       O
XRAY:      la      ka      ka
ELWT:   65.967  10.380  23.653
KFAC:    .5410   .0533   .0838
ZCOR:   1.2194  1.9481  2.8232
AT% :   16.667  16.667  66.667
Can you explain exactly what you have in mind for running this in CalcZAF?  What is it you are after?
If I understand the purpose better I can make it right the first time.
Re: wishlist
« Reply #2 on: September 11, 2018, 02:00:48 AM »
Thanks, I didn't notice that was in standard app.
That will do my current purpose kvalue = concentration * 1/ZCOR. (I trying to see if my measurements match predicted kvalue.
Previously I've also used the absorption parameter when converting from MAN curve to actual background intensity when calculating errors - for unmeasured materials.
Re: wishlist
« Reply #3 on: September 11, 2018, 09:18:22 AM »
No worries, just let me know if you need something else done.
Remember to be sure to change the keV value in the Analytical | Operating Condition menu dialog if you are not at 15 keV!
Re: wishlist
« Reply #4 on: September 11, 2018, 09:45:12 PM »
As you know, the "predicted" values are *just* a model. The values shown will depend on the matrix correction method and MACs selected in the software. Our measurements are (in principle), the true k-ratios.  Assuming of course that we're making good measurements. Which is not always easy to do!
Some day I will attempt to better understand the physics of measuring N Ka in a Ti matrix! I've got a bottle of the TiN material prepared by Bastin many years ago sitting on my desk.  Wish me luck.   :)
