Author Topic: Calcimage faster with hyperthreading disabled  (Read 3557 times)
« on: April 18, 2016, 02:56:52 AM »
I have something interesting here. I am testing my new i7 PfE PC and was doing some calculations. Unfortunately PfE is using only 1 core for everyting it does, so I figured, what happens if I switch of "hyperthreading", which is supposed to make computers faster? In the internet I learned that it should have no effect to switch it off because the modern hyperthreading is cool and is managing cores and threads very well.
I calculated the same calcimage project, once with hyperthreading on, once off. Result:
hyperthreading on: 19.5 minutes
hyperthreading off: 12.5 minutes
So there IS a difference. Amazing!
Now I am wondering if I should switch it off everywhere else too, because I don't really have applicatoins that use it. However on the laptop I have only 2 cores, i.e. 4 virtual ones with hyperthreading on. Since also Win7 64 bit is using some, and there I run more applications next to PfE I might leave it on there.
Will test.
Re: Calcimage faster with hyperthreading disabled
« Reply #1 on: April 18, 2016, 06:19:18 PM »
Will test.
Hi Philipp,
Interesting.
If I were you I would perform a "back to back" test.  Because the 2nd test might be quicker just because it was run 2nd- for example because of disk caching).
So maybe try this:
1. Run with hyper threading
2. Run without hyper threading
3. Run with hyper threading
4. Run without hyper threading
Are 1 and 3 similar?  Are 2 and 4 similar?  OK. Now which set is faster and by how much? Then calculate the variance of each set...     :)
« Last Edit: April 18, 2016, 10:34:59 PM by John Donovan »
« Reply #2 on: April 19, 2016, 03:34:38 AM »
I could do multiple runs, yes.
However, on my computer the hyperthreading is switched off in the bios, which makes a restart necessary. So I don't think the 2nd test had any disk caching or anything. So before each test I made a fresh reboot of the system to have similar conditions.
« Reply #3 on: April 19, 2016, 07:41:17 AM »
If each image calculation was performed just after a re-boot, the test as a whole should be good.  Still might be worth trying both a small image and also a large image and see if the effect is size independent.
I'd be interested if anyone has an explanation for the calculation being faster without hyper threading.
