Here comes the ultimate request to be lazy. So, Andrew Locock has this nifty spreadsheet to recalculate garnet analyses into a gazillion endmembers and other useful things. I also like it because it gives an assessment on the data quality and I always get good grades
![Wink ;)](https://probesoftware.com/smf/Smileys/default/wink.gif)
The spreadsheet is set-up slightly different from the available PFE output options and also contains various elements (Sc, Zr, Sn etc) that are not always part of routine analyses. I always spend time rearranging or adding columns to the PFE output to make it fit and usually have to do it multiple times over when data processing.
It would be great if there could be another custom output (like the H.W. and J.J.D. options) that would just create an output with similar element order (and with empty columns if the element was not analyzed) so that I can copy the output straight into his spreadsheet.
The spreadsheet is attached and the paper can be found here:
https://www.sciencedirect.com/science/article/pii/S0098300408001064In case this is not too much work, this would be a great addition to the list of output options.
