To protect your privacy, you must first log in before you can view forum statistics and user profiles
I was explaining to a class about setting up gas detectors and the difference between differential and integral modes. The question came up as to why one would ever operate in intergral mode. I didn't have a good answer (obviously setting up really tight parameters in differential mode can cause problems) - why not use differential mode with wide windows instead of integral mode?Is this a holdover from earlier electronics?
Yes, that is what we do here as well, we usually use differential mode with a 4 V window. Unless we really try to filter something, where we place the peak in a small window.Good question, I would be interested in an answer too.
