Back in January starting with the release of Surfer v16 from Golden Software, we had to modify where the x-ray mapping output scripts looked for the default "rainbow.clr" file that is distributed with Surfer. Every few years it seems they change the location of this file!
After this last change we edited the various default output scripts to use the following code:
' Load color spectrum depending on version number
If Val(Left$(SurferApp.Version, 2)) <= Val("8.") Then
SurferColorMap.LoadFile(SurferApp.Path & "\Samples\Rainbow2.clr")
ElseIf Val(Left$(SurferApp.Version, 2)) <= Val("15.") Then
SurferColorMap.LoadFile(SurferApp.Path & "\ColorScales\Rainbow2.clr")
Else
SurferColorMap.LoadFile(SurferApp.Path & "\Samples\Rainbow.clr")
Unfortunately when we edited the default slice, polygon and strip output scripts to deal with the new location of the rainbow.clr file in Surfer v.16, we did not notice that the color map object was named differently from the default x-ray map output script. So these slice, polygon and strip output scripts have now been re-edited and are available in the current 12.6.3 version of Probe for EPMA. Just update from the Help menu.
However, the "customizable" scripts provided in Probe for EPMA are not automatically updated because that would overwrite any user customizations. If you haven't edited the custom scripts you can simply grab the latest custom scripts zip file (in case you'd like to start customizing them yourself), in the zip file attached to this post:
http://probesoftware.com/smf/index.php?topic=41.msg6488#msg6488If you have modified your custom scripts for the slice, polygon or strip output, you'll need to edit the color map object in these scripts yourself. The point is simply that the color map object needs to match the object name it is declared with. So in the default x-ray map output scripts the object is declared like this and utilized to load the rainbow color map as seen here:
' Assigns the color spectrum properties to the variable named
Set SurferColorMap = SurferImageMap.ColorMap
' Set color scale significant digits
SurferImageMap.ColorScale.LabelFormat.NumDigits = 3
SurferImageMap.ColorScale.LabelFormat.Type = 3 ' 1 = Fixed, 2 = Exponential, 3 = Compact
Debug.Print "Surfer Version Number " & SurferApp.Version
Else
Note color map object name highlighted in red. What we didn't notice was that the object name in the slice, polygon and strip scripts was named ColorImageMap instead of SurferColorMap!
So the correct code in your custom slice, polygon and strip output scripts should be edited like this:
'Assigns the color spectrum properties to the variable named
Set ColorImageMap = ImageMap.ColorMap
'Set color scale significant digits
ImageMap.ColorScale.LabelFormat.NumDigits = 1
ImageMap.ColorScale.LabelFormat.Type = 1 ' 1 = Fixed, 2 = Exponential, 3 = Compact
'Format text in color scale
ImageMap.ColorScale.LabelFont.Size = 14
ColorImageMap.LoadFile(SurferApp.Path & "\Samples\Rainbow2.clr")
ColorImageMap.LoadFile(SurferApp.Path & "\ColorScales\Rainbow2.clr")
Else
ColorImageMap.LoadFile(SurferApp.Path & "\Samples\Rainbow.clr")
Again, if you haven't edited the custom scripts for the slice, polygon or strip output methods in CalcImage, you don't need to do anything except update Probe for EPMA.
If you want the latest custom scripts and you haven't edited them yourself, you can download the attached ZIP file in the linked post above.
If you have customized these slice, polygon or strip scripts you'll need to manually make the changes above to your custom scripts as described above.
I'm sure I did not explain this very well, so if you have any questions at all, just let us know. Of course I think most users, especially students are simply utilizing the built in output in CalcImage for slice and polygon extractions of quantitative maps as described here:
https://probesoftware.com/smf/index.php?topic=1151.0Quick note: if the in-line images in any posts don't show up as expected, just click your refresh button on your browser and they should show up properly.
