We acquired a set of beam scan maps from the Setup ---> Acquisition menu in Probe Image. We just read in the current location, read in the magnification, then set the dimensions to 500x500 pixels. I have attached one of the S maps. Looking at the header info in Probe Image you are right, there is no XY dimensions in it. Is there some way to manually edit the header if we know what the dimensions are...?
Edit by John: Yes, I confirm there are no stage extents in the image you attached below. I have no idea why that might be. Are you using the latest Probe Image (v. 1.1.0.1867)?
Yes, you can edit the stage extents as the PrbImg file is an ASCII text file. I'm sure you have a Probe Image PrbImg file that does have stage extents so you can compare to the one you are editing, but I'll attach an example Cameca config PrbImg file as an example.
