If you can't see some "in-line" images in a post, try "refreshing" your browser!
Hi John,The default is off peak, which I do not often use anymore. Which file should I dig around in and change so as to default to MAN?
Hi JohnMakes sense. I dug around in the .ini file and couldn't find anything. just wondered if there was something in one of the others. Now... playing devil's advocate... I would say that it must have off-peak as the default somewhere? And then maybe the default can be changed somehow?
