This useful info was posted by Andrew Wager at UMN on the microscopy listserver and I thought worth re-posting here:
I actually figured it out yesterday with some helpful comments from another listserv member and it's just as you said. The format is Lispix (
http://www.nist.gov/lispix/ and for those who use EDX but might not be aware, see also HyperSpy,
http://hyperspy.org/ and DTSA-II,
http://www.cstl.nist.gov/div837/837.02/epq/dtsa2/ ). It is a
raw binary format with each bit of data in a continuous stream, i.e. no delimiter. Each channel of the first pixel is followed by each channel of the second pixel (left to right, top to bottom). An associated "rpl" file tells you the channel depth per pixel and the height and width of the spectrum image. It is uncalibrated (in space
and energy) so that must be taken care of by hand. Bruker opts for 8-bit data, so if you happen to have more than 255 counts in any channel you will have trouble. Esprit appears to truncate the data at the last channel with any counts for sake of file size, so the channel depth is important and potentially variable.
Lispix works great for spectra analysis and moving this data into DTSA. I have not played much with HyperSpy yet. On the off chance anyone else is interested in getting the data into Matlab, feel free to contact me. I put together a matlab script to read the file into a datacube and also perform some basic processing. Simple, but if it
saves someone some time in Matlab, great. I am looking at some exceptionally beam sensitive specimens, so I am playing with probe size, step size, dwell time, and probe current to see what compromises I can make while being able to spatially resolve changes in relative composition. That's where Matlab comes in as I'd like to do running sums of the spectra while also doing 2-D running pixel sums as opposed to just binning or increasing probe size or step size.
Some nice discussion of EDX sensitivity, SDD detectors, and approaches to analysis can be found in this powerpoint:
http://epmalab.uoregon.edu/Workshop2/DonovanWorkshop07_SDD_Newbury.pdfand this associated paper:
http://www.geology.wisc.edu/~johnf/g777/Scanning/NewburyBright-2005.pdfCheers,
Andrew
Note that Probe for EPMA allows for export of EDS spectra in Lispix format as shown here:
![](https://probesoftware.com/smf/oldpics/i57.tinypic.com/a0ulo5.jpg)
