Author Topic: Oxford Aztec  (Read 1484 times)
Oxford Aztec
« on: September 05, 2023, 02:15:48 AM »
Hi
Anyone else have a issue with Oxford Aztec presentation of data where oxides and non-oxides present? i.e. any geological material containing halogens
The elemental column including everything
The oxide column excluding elements without oxygen - F, Cl given zero, and low total
Normally in geology would combined them as below
Seems like a need for another column.
Re: Oxford Aztec
« Reply #1 on: September 05, 2023, 09:05:13 AM »
That's a good point. The question is does one want to see all the elements for a particular data type or all the data types for each element?
In Probe for EPMA the default display method is to show all the elements for each data type, but if one double-clicks a data point in the (lower) data grid in the Analyze! window, a new window pops up that displays all the data types for each element (a la your Oxford example), but just for the data point that was double-clicked.
See here for an example of this feature which a few people are probably unaware of:
https://probesoftware.com/smf/index.php?topic=110.msg1141#msg1141
Sorry that I don't have a suggestion for doing this in the Oxford software... did you ask Philippe Pinard?
Re: Oxford Aztec
« Reply #2 on: December 14, 2023, 07:18:29 AM »
Acquiring x-ray map montages in Aztec
Here's the slowing down of acquistion as the montage continues
Re: Oxford Aztec
« Reply #3 on: December 14, 2023, 07:38:57 AM »
What is orange and what is blue?
Re: Oxford Aztec
« Reply #4 on: December 18, 2023, 06:01:29 AM »
Different pixel sizes
Orange
SE/BSE 512x352 5us
Xray 128x88 10us
Blue
SE/BSE 1024x704 5us
Xray 256x176 10us
Re: Oxford Aztec
« Reply #5 on: December 18, 2023, 08:56:50 AM »
So the larger image mosaics slow down faster is your point?
You should add a legend to your plot, to make that clear...     :)
« Last Edit: December 18, 2023, 09:10:04 AM by Probeman »
