Here's an interesting blog post by Rosie Jones at Oxford comparing various WDS geometries:
https://www.oxinst.com/blogs/why-do-all-wd-spectrometers-not-give-the-same-results?business=nanoanalysis&sbms=nanoanalysis
Most surprising is that Oxford comes out on top...
Interesting design of spectrometer. Is there a collimator attached to the counter (looks a bit like that, but I could be wrong, it however would make sense for higher resolution)? SX detectors has resolution in between those presented curves. Too bad there is no intensity scale on the side of that comparison graph... so what is the price of that higher resolution is not very clear. I would not be surprised if there was quite different analytical conditions utilized to hide higher noise for better resolution if run at same conditions.
BTW, Oxford is well known to have problems with peak-overlaps and thus due to that needs better resolution spectrometers. That is then their R&D clearly had not looked to any other software outside their Oxford software. I had recently been forced to read some quite recent paper (one of authors of paper was from Oxford instruments) there they present WDS (Oxford) as solution to EDS (Oxford, yes Oxford engineer was discrediting EDS of own company to promote other detector of same company) overlapping peaks (oxford software problem to be exact). Ironically that problem is no problem in NIST DTSA-II, which is capable to deal with those situation for already a decade. IMO WDS for SEM is absolute overkill - there are dozen other things which EPMA takes care, which are not on any SEM, and WDS as the sole solution for resolution is to little gain for that price. Inclined WDS (SEM-like) is not very brightest thing too.
... If I would have access to SEM only, I would, indeed, add WDS for different reason - low energy X-rays of light elements (Be, B, C, N, O, F) there that would bring some real difference to EDS.
