...Using the same routine for opening the files that I have always used successfully, last week I began receiving the error message "Could Not Lock File". Any attempt to use any function in Analyze! immediately led to this error message. The files on my hard drive in the Userdata folder no longer worked and only produced this error message
Hi Andrew,
Thanks for providing some context. Well, I must say, this is certainly a conundrum... the closest to this that I've seen is years ago in NT4, when I would update Microsoft Office software and sometimes it would break the DAO (Data Access Object) I use for storing data in the database files. I would then re-install Visual Basic and it would be ok again.
The only reason I mention this is to ask if you can remember last week if you updated anything or installed something, or even uninstalled something. This might be an excellent clue.
Some questions:
Are you logged in as an "administrator" when running these tests?
Have you tried running both the CalcZAF and ProbeForEPMA msi installers?
Do all (old and new) PFE MDB database files show the same symptoms? Is it only PFE MDB files that are complaining about not locking?
Can you open the standard database (Standard.exe) and add a "test" standard? Say PuO2?
What happens if you create a new file in "demo" mode (click "yes" to the first question) and make some new samples, acquire data, etc.?
Have you tried opening the same MDB files on another computer with PFE?
Finally, have you tried editing the file properties by right clicking on the MDB file?
It would be great if you could respond to these questions one at a time when you have a chance.
