Hi Celine, That's pretty weird! I'm sure you've already tried this, but I would first try to setup a new quanti settings file from scratch. I assume you are setting these as GeoSpecies, right? You might try processing with a different species and see what you get, or running as oxide without a species and see how that goes. If you have other things that are running okay with the same standards, etc., it seems species specific. If you calibrate on a plag (Ca, Si, Ca anyway), then run that plag as an unknown, what happens?
