Author Topic: Sputter coater, lateral variation  (Read 589 times)
« on: August 14, 2019, 06:35:09 am »
Here are some maps of a glass slide coated in Au in a sputter coater. The glass slide was mounted centrally beneath the target, which is 57mm in diameter and the stage was spinning.
You can see the Au coat is thickest in the middle 15 mm, and also enriched at the edges of the glass slide. Na does the oppose.
Re: Sputter coater, lateral variation
« Reply #1 on: August 18, 2019, 11:47:30 pm »
Hi Ben
I assume that perhaps this sputter coater doesnt have a rotating planetary stage and is just a single rotation axis?
« Reply #2 on: September 02, 2019, 03:46:17 am »
Yes that's right,
I was just looking are many manufacturers sell rotary-planetary-tilting stages. Have you used one? Do you need to tilt?
