We're pleased to announce a new software product, PictureSnapApp, for sample navigation for EPMA, SEM and TEM instruments. Actually PictureSnapApp will work with any instrument that has an XY or XYZ stage, though we currently only have drivers for FEI, Cameca and JEOL instruments.
This is a very inexpensive application (US$499 for the hardware enabled version), and please note that in the *free* "Text Input" mode discussed below, PictureSnapApp will be useful on any instrument with an X/Y stage
Essentially this is a "standalone" version of the PictureSnap feature in Probe for EPMA, but designed to be utilized on various SEM, EPMA and TEM instruments (and any other instrument in the free "Text Input" mode), using an image of the sample or sample holder obtained from any optical (or other imaging) device. The idea is to be able to quickly take a picture of your sample holder, open it in PictureSnapApp, calibrate it, and navigate your sample holder in say, visible light. For example, navigate quickly to the sample location with the brownish stain...
In addition PictureSnapApp allows one to annotate unlimited points and fields of view (FOV) *and* subsequently move your images and annotations to different instruments, easily recalibrate to the new instrument stage, and then accurately navigate back to those annotation coordinates or any other arbitrary sample location.
PictureSnapApp is available free for downloading here:
http://probesoftware.com/download/PictureSnapApp.msiThis free version of PictureSnapApp software has both a demonstration mode and also a text based input mode. The demonstration mode will allow everyone to play around with the software and see what it does, while the text input mode will allow PictureSnapApp to be utilized on any instrument, even if there is no hardware connection to the instrument stage. Although the text input mode requires the user to enter the stage calibration coordinates using a keyboard.
For this $499 fee (per computer) we provide a registration number which will unlock the interface drivers for the FEI DCOM interface for all FEI SEM and TEM instruments, and also the EIKS interface for all JEOL SEM, TEM instruments (and also JEOL EPMA instruments for those that do not already have our Probe for EPMA product). We hope to add support for additional instrument vendor SEM/TEM stages soon.
Edit: We have now also added support for Cameca EPMA instruments if you don't already have our Probe for EPMA product or want the image annotation and image/stage transformation capabilities of PictrureSnapApp for moving images and annotations between different instruments...
Attached below (remember to login to see attachments) is a flyer describing the basic functions of the PictureSnapApp software. As a reminder, this app can import any JPG, GIF or BMP image up to 32K by 32K pixels for detailed sample navigation. For example the document camera described here is an inexpensive ($99) device for taking high resolution images of your sample or sample holder:
http://probesoftware.com/smf/index.php?topic=999.msg6635#msg6635However, the image source can be from any device including other optical or beam instruments or even your cell phone camera! In addition, any text annotations (which are calibrated in stage coordinates), will be automatically transformed if the files are transferred to another instrument and re-calibrated to that instrument's stage coordinate system.
But the best way to learn the software features and capabilities is to download it (it's free) and try it out!
Please contact Barbara (barbara@probesoftware.com) for pricing and other details.
PictureSnapApp Version Changes:
01/09/2024 Add feature to import point annotations in stage coordinates to the point annotations dialog. Also add "Delete All" button.
v. 1.8.8
08/02/2023 Add options for embedded image border and filename (von der Handt).
v. 1.8.6
12/27/2022 Add stage coordinate entry dialog (Neill).
v. 1.8.5
06/16/2022 Add display of current mag to main window. Add right and left arrow keys for 2% change in mag for demo and text input modes.
Add new keyword in PictureSnapApp.ini for setting initial magnification (demo and text input modes only):
[hardware]
InitialMagnification=100
06/12/2022 Add FOV label for "typical" FOVs for FEI, JEOL and Cameca instruments at 100x (horizontal FOV).
v. 1.8.2
03/24/2021 Add INI keywords for modifying Cameca (SX100 and SXFive) stage motor speeds (Neill). See new entries for:
v. 1.8.2 XMotorSpeedCameca=10000
YMotorSpeedCameca=10000
ZMotorSpeedCameca=10
12/29/2020 Update copyright.
v. 1.8.1
09/03/2020 Modify Current Stage Position window to update position automatically, unless user is entering new stage positions.
v. 1.8.0
08/14/2020 Add stage position menu to Window menu
v. 1.7.9
02/13/2019 Modify stage limit drawing code to handle rotated samples.
v. 1.7.7
11/14/2018 Add code to automatically read stage limits and check for locked axes on FEI instruments.
v. 1.7.6
11/3/2018 Add code to display stage limits on main PSA window and also full view window (Seward).
v. 1.7.5
09/22/2018 Fix code for error when closing app on 32 bit operating systems (Neill).
v. 1.7.4
09/15/2018 Add red annotation color. Fix JEOL SEM stage orientation.
v. 1.7.3
09/13/2018 Fix bug in JEOL 8900/8200/8500 comms interface.
v. 1.7.2
08/24/2018 Modified the update download code to utilize https secure connections.
v. 1.7.1
08/03/2018 Re-set the PictureSnapCalibration mode automatically back to two points when loading a new uncalibrated image.
v. 1.6.9
07/25/2018 Fix un-calibrated image bug in display current mag box code.
v. 1.6.8
07/19/2018 Modify GDI+ graphics to open/close in form load/unload events to prevent Microsoft memory leak.
v. 1.6.7
07/17/2018 Fix blinking problem with graphics drawing.
v. 1.6.6
07/11/2018 Modify ruler measurement feature to utilize GDI+ for anti-aliasing graphics.
07/08/2018 Add export of sub image ACQ calibration files from Image Locator window.
v. 1.6.5
07/07/2018 Add code to handle stage to image rotation for adding calibrated images and draw rectangle modes.
v. 1.6.3
06/29/2018 Add code to rotate annotations in PictureSnapApp transform menu dialog.
v. 1.6.1
06/27/2018 Add measurement tool to PictureSnapApp (Langworthy).
v. 1.6.0
06/20/2018 Add calibration accuracy output and Load ACQ from external file to Calibrate Image window.
v. 1.5.9
06/15/2018 Add "Select Remote Image" button to Image Locator feature.
v. 1.5.8
06/07/2018 Improve code to automatically handle updating of annotations and sub images after user clicks Calibrate Image. Add
v. 1.5.7 checks for stage tilt and FOV orthogonality.
06/03/2018 Add hand cursor for Image Locator feature to show pan/zoom capability. Fix image rotation display in Transform dialog.
v. 1.5.6
06/02/2018 Add image mosaic feature (in hardware enabled versions). Add automatic conversion of point/FOV and sub image calibration coordinates from stage to screen. Makes the conversion to/from different stage systems better and *much* easier to code.
v. 1.5.5
05/26/2018 Resize image display for smaller images.
v. 1.5.4
05/23/2018 Add Image Locator feature with zoom and pan.
v. 1.5.3
05/16/2018 Improve stage config dialog, File Save As options.
v. 1.5.2
05/09/2018 Add additional tools for configuring and testing the FEI DCOM connection. Updated installation instructions.
v. 1.5.0
04/12/2018 Move stage to current position (if in bounds) when loading new image- just for moving main window to current position.
v. 1.4.9
04/07/2018 Add support for JEOL 8800/8900/8100/8200/8500 EPMA instruments (support for 8230/8530 instruments using
v. 1.4.8 existing EIKS interface.
04/01/2018 Add image rotation feature for when the sample must be mounted in a different orientation from another instrument.
v. 1.4.7
03/28/2018 Add digitize current position, rectangular/line drawing and new quick start popup.
v. 1.4.5
03/26/2018 Minor improvements.
v. 1.4.4
03/24/2018 Add support for "half-cartesian" stages (e.g., LA-ICPMS). Add support for "nm" units and also automatically convert images
v. 1.4.3 when loading them.
03/17/2018 Add "transform" dialog for unit conversion. Stage orientation code next!
v. 1.4.2
03/15/2018 Add Cameca EPMA support. Minor improvements.
v. 1.4.1
03/09/2018 Add recently open file list and FOV annotations. Add Move To buttons for both point and FOV annotations.
v. 1.4.0
03/01/2018 Implement labels for calibration points. Improve annotation code (Seward).
v. 1.3.9
02/28/2018 Implement new options for defining the IP address of the instrument. Add option to disable Z stage movement.
v. 1.3.8
02/12/2018 Fix missing file issue.
v. 1.3.6
02/10/2018 Add mouse cursor movement display of stage coordinates to full view image
v. 1.3.5
02/09/2018 Initial release of PictureSnapApp
v. 1.3.4
