Author Topic: Bruker Quantification Methods  (Read 2550 times)
« on: August 29, 2015, 02:52:08 pm »
The latest version of PFE (11.0.3) now allows the user to specify a Bruker quantification method for extracting net intensities as seen here:
« Last Edit: August 29, 2015, 10:26:04 pm by John Donovan »
  • Global Moderator
Re: Bruker Quantification Methods
« Reply #1 on: September 02, 2015, 09:47:19 pm »
I've tried this and PFE presents me with that dialog box when the first measurement is started.
Is there a way to change the quantification method selection afterwards? I would have to change settings in the method for different materials.
Karsten
« Reply #2 on: September 02, 2015, 10:07:12 pm »
Karsten
Hi Karsten,
Right now you'd have to close the app and re-start the program.  But it would be easy enough to add a menu to pop that Bruker quant method dialog back up.  Question is: where should the menu go?
Or were you thinking that we could assign a different EDS quantification method to each sample?
« Last Edit: September 02, 2015, 10:24:12 pm by John Donovan »
  • Global Moderator
« Reply #3 on: September 02, 2015, 10:32:40 pm »
If I could select a method on a per sample basis that'd be ideal.
How about in Analyze | Calculation Options in the "EDS Spectral Data and Calculations" section?
« Reply #4 on: September 03, 2015, 08:22:29 am »
I was thinking the same thing!   I'd have to bump the version number and save it to the MDB file though.
One related problem: I like to make things symmetric as much as possible, but unfortunately the quant method for Thermo is selected by a call to the TEVB_ProjectExplorerDisplay function which remotely opens the project selection dialog in NSS and that doesn't return a project name.  I'll talk to Thermo and see what they suggest.
Philippe Pinard
  • Post Doc
« Reply #5 on: October 12, 2015, 02:19:35 am »
A note for new methods to appear in the list, they cannot have any "Halt execution" check in the method definition.
I also obviously agree with Karsten that it would be a nice feature to change the Quant method in the calculation options.
« Reply #6 on: October 12, 2015, 09:13:01 am »
Hi Phillipe,
Yes indeed. This is already implemented as seen here:
' Only use quantification methods that do not require user intervention
tAutomaticOnly = True
BrukerError& = GetQuantificationMethods(BrukerHandle&, tAutomaticOnly, pMethodBuf$, Len(pMethodBuf$))
Call BrukerEDSSpectraProcessError("BrukerEDSSpectraSelectQuantMethodOrProject", "GetQuantificationMethods")
If ierror Then Exit Sub
Also already implemented at the sample Calculation Options dialog level.  Please try it out and let me know how it works.
« Last Edit: October 12, 2015, 09:36:45 am by John Donovan »
