Author Topic: Latest JEOL Driver Version  (Read 11148 times)
« on: March 27, 2014, 12:07:35 PM »
The latest JEOL driver version 1.6.2 fixes a rare but nasty "same command executed" error (1004) that can occur on 8230 and 8530 instruments.
Please contact Probe Software for an updated JEOL driver.
« Last Edit: April 05, 2015, 10:52:09 AM by John Donovan »
Re: Latest JEOL Driver Version 1.6.2
« Reply #1 on: February 11, 2015, 11:52:15 PM »
All,
If you buy a new computer for your lab (e.g., Win 7 64 bit), you will need to move the existing JEOL driver from the old computer to the new computer. Otherwise you will get the following error when you try to connect to the instrument:
File not found: amb_jeol8x00.dll
Here are some tips:
1. To begin with you will need to contact us for a new registration code once you see the following dialog on starting Probe for EPMA:
You should click the Copy button and paste the serial number into an email and send it to us. We will respond as soon as we can with a registration code. Just copy and paste the supplied registration code into the registration field and click the Register button.
2. The old driver will normally be in the Windows\System32 folder. Simply copy the amb_jeol8x00.dll file from the old computer to the new computer and place it in the following folder depending on the OS:
All 32 bit Windows OS systems: C:\Windows\System32
All 64 bit Windows OS systems: C:\Windows\SysWOW64
That is all!
« Last Edit: February 12, 2015, 04:46:23 AM by John Donovan »
UT E-Beam Lab
  • Student
    • UT Austin Electron Microbeam Laboratories
« Reply #2 on: February 12, 2015, 04:00:46 PM »
Thank you so much, John. I've successfully replaced the Windows XP computer with a Windows 7 computer.
« Last Edit: February 12, 2015, 04:07:33 PM by UT E-Beam Lab »
Re: Latest JEOL Driver Version 2.02
« Reply #3 on: March 27, 2015, 07:56:44 AM »
The latest JEOL driver DLL is 2.02, just minor internal changes:
What's New
Version 2.0.2 - 25-Mar-2015
  - Cleanup of bug in new initialization code.
Version 2.0.1 - 6-Mar-2015
  - Cleanup of some of the initialization code.
Version 2.0.0 - 28-Jun-2014
  - Changes to the log generation to be more Windows 7 (and later) compatible. Log
    files are now created in the users Documents location instead of the folder that
    holds the executable (this folder may not be writeable). Log file name will be
    generated from the app name as - <appname>_J8X00.log
  - Improvements to the build system
Contact Probe Software to receive this new DLL.
Re: Latest JEOL Driver Version (v. 2.0.3)
« Reply #4 on: November 02, 2015, 07:26:41 PM »
Remember,  If you install v. 11.x of Probe for EPMA on a new computer you *must* utilize version 2.0.3 of the JEOL (or Cameca) driver!
What's New
Version 2.0.3 - 25-Aug-2015
  - Added support for Probe for EPMA's new common app data folder for
    initialization parameters.
« Last Edit: November 02, 2015, 11:23:01 PM by John Donovan »
Re: Latest JEOL Driver Version (v. 2.1.0)
« Reply #5 on: September 28, 2016, 02:53:14 PM »
The latest JEOL driver is 2.1.0 and the changes are listed here:
What's New
Version 2.1.0 - 4-Mar-2016
  - Added support for beam current setting on the 8230/8530
Remember, the dll driver file should be copied to the folder based on your operating system version. Simply unzip and copy the amb_jeol8x00.dll file to the following folder depending on the OS:
